- Mute
03-26-2025 06:09 PM in
Galaxy S22I first noticed this issue last December—when my phone dies, the battery no longer charges using a wired connection. I usually try to prevent my phone from dying, but due to frequent travel for work, I don't always have time to keep it fully charged.
I've already had both the battery and charging port replaced, but the problem persists. When the phone dies and I plug in a wired charger, it initially shows the charging symbol, but after about 15 minutes it goes away and nothing happens.
The only way to get it to start charging again via a wired connection is to first use a wireless charger for a few minutes. After that, I can switch to the wired charger, and it works.
- Mute
03-26-2025 07:04 PM in
Galaxy S22Maybe try to get a battery pack for travel. Battery packs come in clutch when on the go a lot.
- Mute
03-26-2025 07:05 PM in
Galaxy S22
