Problems with setting up voicemail on my Samsung S22
(Topic created: 05-21-2023 10:43 AM)
andre66
Galaxy S22
I'm having problems setting up my voicemail on my Samsung s22
JBTechfanatic
Black Hole
Galaxy S22
Voicemail is a carrier option. Open the dialer and hold down 1 and follow the prompts necessary to setup your voice mail. If that won't allow you then you must call your carrier and have then link your Sim to your account over again. But first try the automated process dialing 1
1 Reply
JBTechfanatic
Black Hole
Galaxy S22
