S22 Ultra Voicemail Problems with Verizon
(Topic created: 01-24-2023 06:45 AM)
Adamr0885
Galaxy S22
In order to check my voicemail, I have the only option of dialing * 86. The voicemail app from Verizon no longer notifies me or even allows me to check voicemail through the app since the beginning of December.
I have called Verizon technical support over the past 3 weeks and they are unable to fix the issue. I have reset my phone, clear the cache and data for my phone and voicemail apps. Still, I am not able to be notified of my voicemails on my phone.
Samsung_Moderator
Galaxy S22
Hey there! I can certainly understand how important it is to have a working voicemail. Unfortunately voicemail is a carrier feature, it may be best to reach out directly to Verizon for additional help to get it back working! Thank you so much for being a part of our community!
Yamialex224
Honored Contributor
Galaxy S22
Verizon is falling apart my friend works as a nursing home and anyone with Verizon there has issues
PRODIGY72
Galaxy S22
Download the Verizon Visual Voicemail. It was updated recently. You should also be able to press the 1 key on your dial pad. It is short coded to your providers VM system.
Samsung_Moderator
Galaxy S22
