S22 not connecting for car Bluetooth calls
(Topic created: 02-24-2022 07:02 PM)
user9Hhf8wARr2
Galaxy S22
I updated my S10 in early January 2022, it would no longer connect to my Toyota Camry for Bluetooth phone calls. I just upgraded to an S22 and the issue continues.
I followed recommendations on this site and Reset All Settings and Reset Network Settings. The issue continues,
The phone connects for a brief time and then disconnects, Intermittently I am getting Google Stops Working Error.
I'm at my wits end, please help.
JUMP TO SOLUTION
Philosophics
Nebula
Galaxy S22
Apologies, I meant 2ft.
None of the cables I have acquired from Samsung have ever worked right.
Sometimes, AA would load but as soon as the phone was bumped, AA would disconnect.
The cable needs to be really short.
MikeOnTap
Galaxy S22
This is what I'm dealing with20220312_092237_3121_1647112985.jpg20220312_092332_3123_1647113022.jpgScreenshot_20220312-092319_Android Auto_3122_1647112999.jpg
MikeOnTap
Galaxy S22
Or this20220312_090016_3119_1647111634.jpgScreenshot_20220312-090041_Settings_3120_1647111641.jpgScreenshot_20220312-090003_Android Auto_3117_1647111604.jpg
userYTLJpKJcLt
Galaxy S22
I used the same cable with my s20+ and my husbands phone it is thr s22 ultra that is the problem
Sridhu
Galaxy S22
I have a Pioneer AVH-Z5090BT and I have the same  issue - no google maps.
The music does play & the display says "Android Auto" but otherwise the screen is blank.   Not able to receive calls either as the phone related buttons do not show up.
I am on 8.36 on the head unit & Android 12, updated on Saturday.
Other phones, including a Samsung (A50), on Android 11 work fine.
At the moment, it is worse than useless as I am unable to just use bluetooth connectivity for audio & the phone itself for navigation.
BTW, the S22 connects fine with the newer Pioneer DMH-ZS9350BT. So the issue might be with backward compatibility rather than just a S22 or Pioneer issue
Music playing on Android Auto.Music playing on Android Auto.
Blank  screen when the AA button is clickedBlank screen when the AA button is clicked
Sridhar
Birchs
Galaxy S22
S22+ and I have a Pioneer AVH-2550NEX and it has the same symptoms. no display. same phone and cables work on other vehicles, but i have tried multiple cables. this same head unit and cables worked with my S20+. i just got off the phone with Pioneer and they said it's a phone issue and samsung has been aware of it for a month.
user32YVhCcID6
Galaxy S22
Same here. Not a cable issue other devices work fine. Full factory reset on head unit as well.
S22 Ultra, Pioneer AVH-2550NEX.
My head unit is one behind on firmware which I will update but I doubt that will matter based on what I am reading everywhere.
userScDhVQa7xV
Galaxy S22
Just got the S22 and Android Auto will not connect.   Is anyone else having this issue?  I have tried several times with different cords to no avail.
Thanks in advance!
userVML3hkVQkA
Galaxy S22
⁰0
