SVOGT302
- Mute
11-21-2023 01:04 PM in
Galaxy S23
They were in color & with my eyesight are difficult to see. How can I change to color?
Solved! Go to Solution.
jeff86
Cosmic Ray
- Mute
11-21-2023 01:50 PM in
Galaxy S23
Download Theme Park. It'll allow you to change those colors to whatever you want. First thing I did after the Android 14 update. I couldn't stand the plain gray look.
jeff86
Cosmic Ray
- Mute
Galaxy S23
SVOGT302
- Mute
11-22-2023 12:24 PM in
Galaxy S23
Thank you.... It worked!
SVOGT302
- Mute
11-24-2023 03:31 AM in
Galaxy S23
Both suggestions I got worked! Thank you
- Mute
11-21-2023 02:13 PM in
Galaxy S23
Also if you go into settings and search "color palette" you'll find a setting that, while disappointing, is still better than the default grayscale after all that time with blue buttons.
SVOGT302
- Mute
Galaxy S23
Thank you.... Much better!
![](/skins/images/58395F307013B0F94C185F957C761EAB/responsive_peak/images/icon_anonymous_message.png)
