Galaxy S24 Battery Drain
(Topic created: 01-28-2024 05:28 PM)
GitDatPC
Galaxy S24
Always On Display drains nearly 2% of battery per hour on my S24 Ultra. This is much higher than the S23 Ultra. Hopefully this will be fixed in an update?
JUMP TO SOLUTION
userMl5jSKbd5E
Galaxy S24
Same here...the first patch literally ruined everything
DakVlk
Galaxy S24
Same here! I reported the problem this morning. Does anyone have an update on the problem?
Gufran
Galaxy S24
Since last update my S24 ultra is draining battery very fast and not improving
