There is a problem with the sensors - body composition
(Topic created: 01-21-2025 11:41 AM)
Ferret_monkey
Galaxy Watch
ā€ƒ
Hi there, I recently purchased the Galaxy Watch6 Classic and despite the fact that the silver looks cheap and ugly, I'm mostly happy with the watch, although a few days ago it started producing an error when I try to measure my body composition.
The second I put my two nominated fingers on the buttons/sensors it immediately says 'there is a problem with the sensors. Contact customer support.
The watch has no problem measuring anything else, it's just the body composition feature which worked just fine until a few days ago.
To be clear, the rear of the watch is clean and unobstructed. The contact with my wrist is perfect and my fingers have no oil or other substances that should negatively impact on their contact with the button/sensors.  I do not have a fake tan or anything else to consider. I have the latest software update... Which might be related to this issue as it updated around the same time that the error first appeared.
Assistant would be greatly appreciated.
Thanks
LongHiker
Galactic Samsung Care Ambassador
Galaxy Watch
I would contact Samsung Customer Support as the message suggests. Since it worked until recently the sensors hardware may have failed.
king3616
Galaxy Watch
I hope I get it fixed
Scottla94
Galaxy Watch
Also recently got this same message also all other sensors work including ecg
lostnsoundwaves
Galaxy Watch
This is exactly the issue I came here to look into. I, too, received this message two days ago after having no problem using the BIA function every day for the last 6 months at least. I received the One UI 6 update around a month ago or so, and was able to continue using BIA without trouble. Just a couple days ago, however, I received another watch update, after which my watch had a notification saying it had been updated to One UI 6... again? After receiving what I can only figure was a patch, my sensors no longer function for BIA and I get the message mentioned above. All other functions work perfectly fine.
Ahmed Gado
Galaxy Watch
same problem as me, it seems an issue caused by the last update, please fix this issue
CatalinCT
Galaxy Watch
Same problem. I don't know what to do and this is not my first time. I had a Galaxy Note 9 and after update my screen got green display issue. I think i will not buy Samsung next time. Samsung are dissapointing me every time i buy something new from them.
userwFNyy8t7GO
Galaxy Watch
I have the same issue. I contacted customer service and they want me to pay almost $100 just to get it checked.
mkfernando
Galaxy Watch
I have the same problem here. Only the BIA sensor is not working. It seems to be after the last update.
SleepDeprived
Galaxy Watch
Body composition stopped working for me after I've updated the watch from the android 13 to android 14. And ECG now is very very "noisy" now. Before that it was working perfectly and the ECG graph was like from a some real medical equipment.
