Samsung Smart TV does not see digital flat antenna
(Topic created: 10-19-2023 08:27 PM)
user03ORElUfCU
LED and OLED TVs
I've used four different coaxial cables to hook into the antenna by Channel Master and hook it back into my Samsung Smart TV and nothing. Kind of out of ideas and can really use some advice
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! I see how this can be frustrating with not being able to use your antenna. I would recommend trying the steps in the link below.
https://www.samsung.com/us/support/answer/ANS00062206/
1 Reply
Samsung_Moderator
LED and OLED TVs
