Displaying Phone on TV
(Topic created: 10-17-2023 07:11 PM)
user6vL7pecNkn
LED and OLED TVs
When I mirror my phone to the TV and view the Samsung Gallery I cannot get the photos to display other then very small in the middle of the TV screen even though they are full screen on the phone (S23+ with up to date software). Is this possible or is there no way to make the photos larger in the TV?
Thanks
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! You should be able to change the screen size by the following.
1. Go to Smart View > Tap on More Options (three vertical dots).
2. Tap Settings > Phone aspect ratio.
3. Select Full Screen on the connected device to make it a full screen.
If this does not help I would recommend reaching out to our smart things community at the following link: https://community.smartthings.com/
1 Reply
Samsung_Moderator
LED and OLED TVs
