Trouble using antenna with Smart TV
(Topic created: 07-26-2019 06:59 PM)
iluvgolf18
LED and OLED TVs
I am trying to hook up an antenna to my Samsung 4k HD Smart TV.  When I go to the Source menu, there is no source for the antenna.  If I click on the TV option, it brings me to TV Plus instead of prompting me to scan for over the air channels.  Also, when I go to Settings and then Broadcast, the Broadcast option is greyed out.  My TV is connected to the Internet.  I checked for updates and there were none.  Any help in this matter is greatly appreciated!  Thanks!
JUMP TO SOLUTION
userfUF0LTgLw0
LED and OLED TVs
Thank you for posting this worked!
usericXx8ZUsOV
LED and OLED TVs
You must first select TV or TV Plus depending on TV model or age to put the TV in broadcast antenna mode . This will cause Broadcast TV to no longer be grayed out. Now go to settings and select Broadcast TV the Scan Channels. Ffor more detail see the following  link:
https://www.samsung.com/us/support/answer/ANS00062206/
cindyloujack
LED and OLED TVs
I purchased a Samsung series 7 TU7000 Crystal UHD TV a few days ago. I am so frustrated and disappointed. I also have antenna hooked up as I do not want a satellite service. The older TV (not smart TV) has 138 digital and 3 analog channels. The new Samsung gets MAYBE 9 channels, yet it scanned in 16 (7 of which say mode not supported, or not available. Can't even get Fox News app.
userjWqbJlQrFD
LED and OLED TVs
I can not get this Samsung TV to change from cable to antenna
SamsungPrince
Honored Contributor
LED and OLED TVs
Oh no!  Here's a link with some info to get you back viewing television with your antenna: https://www.samsung.com/us/support/answer/ANS00062206/
DavidLowe
LED and OLED TVs
So question I am trying to connect a vcr to the antenna (coax cable) port but I don't see how to select that input!!
user55PngKVmUb
LED and OLED TVs
Hi, same issue here. My tv does not show up air-tv option in the sources. My model is UN75AU8000FXZA
user7EpDSpctcR
LED and OLED TVs
Hi. I had the same issue. It does not come up under antennae input.
Go to settings/broadcast/auto program
Select "air' for how to get your channels.
Make sure Antennae is close to a window.
It will scan and then place the Live TV icon on your hub.
Good luck.
Samsung_Moderator
LED and OLED TVs
Thank you so much for sharing!
