Connecting 2 sound systems
(Topic created: 06-27-2024 07:09 PM)
Tgolomb
Home Theater
I have a Samsung 65 inch class Q60D series QLED 4K smart and
I have the Samsung soundbar and subwoofer model HW-Q850D. I am using the hdmi arc for the soundbar. When I listen to music it doesn’t sound as good on the soundbar vs my denon receiver.
my question is can I use the hdmi2 on the tv and  switch between the 2 system’s
SamsungTam
Honored Contributor
Home Theater
Hello! @Tgolomb Thank you so much for posting about this. Unfortunately, we can't guarantee compatibility between two sound systems.
1 Reply
SamsungTam
Honored Contributor
Home Theater
