- Mute
08-08-2024 07:36 AM in
Home Theater
Hi everyone
I bought a sound bar q930d and it works efficiently. But I read on Samsung's website that it supports Alexa built-in. So i downloaded the smart thing application and linked the Sound Bar and also downloaded the Alexa application and linked it to the smart thing application.
The problem is that I don't find a feature to connect the sound bar to Alexa. Does this Sound Bar support Alexa bulit-in or not?
Solved! Go to Solution.
- Mute
08-12-2024 07:24 AM in
Home TheaterHi there, Thanks so much for asking about this. I found this helpful article with detailed information about using Alexa with your Samsung soundbar:
https://www.samsung.com/us/support/answer/ANS00078932/
Please let us know if this helps.
- Mute
