Does anyone know why Smart Things will not let me turn off “ice bites” in my Samsung refrigerator?
(Topic created: 09-04-2023 08:25 AM)
OhioSpyderman
Kitchen and Family Hub
It works for the larger cubes, but not for the smaller bites.
If I go to the actual refridgerator controls and turn off the LOCK, then I can turn off the smaller bites.
I do not, however have to turn off the lock to change turn off (or on) the larger cubes.
Is this an app issue?
Bob.
Samsung_Moderator
Hi there, I'm sorry to hear you haven't been able to find a resolution for this yet. I recommend reaching out to our dedicated SmartThings team, as they will have the best tools and resources to help with this. You can reach them directly by calling 1-866-813-2404. They should be able to confirm what features are currently available, as well as walk you through how to use and troubleshoot these features.
StrobesAU
I’m having the same problem! It thinks for a bit, then the toggle switches off and back on again.  I can’t figure it out!
Lazarof65
I am having the same issue. I wish someone at Samsung would reply with an answer.
Sandy D
I just bought this refrigerator and have the same issue. Did you ever figure it out?
OhioSpyderman
Unfortunately, no 😕
Bob.
Samsung_Moderator
