How to get a family hub Samsung refrigerator out of retail mode?
(Topic created: 11-08-2017 06:28 PM)
userzmlrlCXZbU
Kitchen and Family Hub
We purchase the floor model smart refrigerator from JCPenney and it is stuck in retail mode even after I performed a factory reset from the settings menu. It has no apps on it except the retail mode app. How do we set this up for use at home?
JUMP TO SOLUTION
userSvtQGYkToR
I can tell you right now, as a appliance salesman for Best Buy, "your retail" doesn't have a clue how to fix that!
usermXWHiAWRui
Hi... I have the same problem. Could someone provide me the manufacturer "password"? I have the PIN, but now the fridge is asking for a pasword. It is making me crazy!!!
@CourtneyP
userCFuAO5nNo8
Rf28NHEDDSR/AA HOW TO GET PASS THE RETAIL MODE PASSWORD
userWrUoHQ2jxk
Ran into this myself. Here's what you do. Hold the list button (the one with three lines ) for about 3 to five seconds. That should get you to factory reset and then you can follow the prompts from there make sure you have set up a Samsung account before this and it will go a lot faster
usermXWHiAWRui
It doesn't work for me, do you have any other recommendations?
user0mnzqlvaIh
I followed reddit post on "rescue mode" and that worked for me
below worked for me
Rescue mode:
1) open/run fridge manager app from family hub
2) Press and hold recent apps or home for 10 seconds
3) white screen comes up with menus - select factory reset
4) Once factory reset is done, you'll be out of retail mode.
mordorbg
Life saver!!!!!
