How to get a family hub Samsung refrigerator out of retail mode?
(Topic created: 11-08-2017 06:28 PM)
userzmlrlCXZbU
Kitchen and Family Hub
We purchase the floor model smart refrigerator from JCPenney and it is stuck in retail mode even after I performed a factory reset from the settings menu. It has no apps on it except the retail mode app. How do we set this up for use at home?
user0mnzqlvaIh
I followed reddit post on "rescue mode" and that worked for me
below worked for me
Rescue mode:
1) open/run fridge manager app from family hub
2) Press and hold recent apps or home for 10 seconds
3) white screen comes up with menus - select factory reset
4) Once factory reset is done, you'll be out of retail mode.
SamsungPrince
Honored Contributor
Could you provide the full model of the fridge?
userzmlrlCXZbU
Sorry, we just took the refridgerator back to the store. Thanks
userLRKAMqXb4r
WHAT WAS THE SOLUTION, I HAVE THE SAME ISSUE,
Courtney P
We have the same issue.  Model RF22M9581SG.  Just had it delivered and can't get it out of Retail Mode.  What do we do?
SamsungTam
Honored Contributor
@Courtney P, thank you for that. If the fridge is displaying retail demonstration videos, please click on the link for the instructions on how to turn off Retail mode.
Courtney P
Followed the Left/Right pattern in the link but it didn't do anything.  Still in Retail Mode.
SamsungTam
Honored Contributor
@Courtney P, where was this unit purchased at? Have you reached out to the retailer regarding this issue?
userkU7QdVfd9u
That link is dead-- please provide instructions.
MsBri1
Black Hole
Hello there, I recommend reaching out to your retailer for the password.
