Refrigerator dispenser light not working
(Topic created: 10-13-2022 07:12 AM)
Members_bFJytoj
Kitchen and Family Hub
Refer model RF28R7351SR/AA
My dispenser light doesn't work.  I am assuming this refer should have one.
What should I do?
Samsung_Moderator
Hello and thank you for reaching out to our Community regarding the dispenser lighting. After thorough research, it does not appear your model has the external lighting however the dispenser's panel does have LED lighting when engaged. If you have any other questions I encourage you to review the specifications from our website online, I've included the link here- https://www.samsung.com/us/home-appliances/refrigerators/4-door-french-door/28-cu--ft--4-door-french....
Please note some of our models in the series RF22R, RF23R, RF24R, RF28R, and RF28A, are not manufactured with a dispenser light as of Jan. of 2022. Units manufactured before this timeframe may include a dispenser light. However, this specification was changed in later models. We apologize for any inconvenience.
Thank you so much for being a part of our Samsung Community and feel free to use any contact method listed below if any further assistance regarding this matter should occur:
Facebook- https://www.facebook.com/samsungsupport/
Twitter- https://twitter.com/SamsungSupport/
Instagram- https://www.instagram.com/samsungsupport/
or
Private Message by selecting any moderator and clicking on the chat option.
Samsung_Moderator
or
nickoredson
  • Does the Samsung RS27T5200**Refrigerator ice maker/dispenser have a light? If so how do I get it to come on?
Samsung_Moderator
Hi there, Thanks so much for asking about this. I've checked the user manual (linked below) to be sure, but this model does not have a dispenser light.
https://downloadcenter.samsung.com/content/UM/202002/20200201091442956/SBS_RS5300T_DA68-03958J-01_EN...
Stick55
I just purchased a RF22A4221SR smart refrigerator and there’s no light when using the water dispenser. It appears to have a light under the top of the left side but it doesn’t come on.  Am I missing something? I would think it would have one, you shadow the front of the fridge when using it.
JBTechfanatic
Black Hole
Unfortunately their is no light on the dispenser listed in the Spec's
Stick55
I see that they stoped installing them in this refrigerator in January of 2022. Such a simple little thing that makes a big difference. I’m betting the wire harness still has the plug in for it.
