Refrigerator family hub touchscreen unresponsive/display doesn't work
(Topic created: 11-20-2018 05:45 PM)
userop64rKJLlo
Kitchen and Family Hub
My family hub touchscreen does not respond to touch since yesterday , I can’t unlock the screen. I turned off the screen and turned it back but I can’t unlock the screen. I unplugged the fridge and it didn’t work either.
JUMP TO SOLUTION
userp6Pm3xEigU
How are you supposed to get to "settings" if the screen is frozen??!!
userBX8kpKbe1Y
My screen seems to be unresponsive during the day. I was able to upgrade the software at 1am and do anything. At 8am it was locked again. I tried the switch and unplugged it but nothing. If there's a locking feature I can not get to it because the screen is frozen. Any suggestions
Not applicable
Have you tried leaving it unplugged for 10 minutes? Are you able to connect to it via the app?
userOaIlmBB7G7
So on a previous tread you said to unplug the fridge for 5 minutes now your saying 10 minutes. And to try the screen power switch. My screen won't respond and your responses contradict each other. Confusing how an expensive fridge has so many issues between the ice making, touch screen not responding, and moderators contradicting themselves.
userNMFrx8ve1i
I have the same issues, I had a technician come to fix the icemaker (lucky me, i had 5 year full warranty through the store i purchase from)
A week ago i did update the software, since then the screen is unresponsive. I have tried to turn off for a while and then on, still didn't help at all.
I wish i wasn't upgrade the software, it used to work perfectly before (beside the app on the phone - i gave up 3 years ago)
Please, any one know how to get back to previouse firmware?
userpRduvCVDKb
The fridge is less than 2 years old. And the touchscreen is totally unresponsive to touch. Can't swipe or do anything ... has anyone found a solution ? Already tried turning on/off red switch and power cycle the fridge 1000 times. How  can this happen ? Was it a software update ?
flowerchld
I have the same issue. The screen saver turns on and is stuck there, the screen is unresponsive. My fridge is only a year and a half old. Samsung has really dropped the ball on this one. There are a lot of complaints and repair techs are saying this is a common issue. I paid $3000 for a big brick.
SamsungJam
I would be happy to look into this.  Could you send me a private message with the full model and serial number?  http://bit.ly/2ihPL97
userpRduvCVDKb
i am certain the software update turned this into a brick
DiegoLondono
Same here.  Model rf265beaesr.  I restarted everything and still frozen.
