Samsung Freestanding Gas Range Clean inside door Glass
(Topic created: 02-27-2025 06:49 PM)
JBTosti
Kitchen and Family Hub
What should I use on the glass on the door inside the range? The glass has gotten greasy splatter all over it. I really don't like using harsh chemical type cleaners.
I have asthma, and many products cause an asthma attack.
Thank you for any advise
1 Reply
Before you try any cleaning agents, refer to your stove's manual first.
Baking soda is a mild alkali that helps to break down grease and grime.
Mix baking soda with water to create a thick paste, and apply the paste generously to the inside of the oven door glass. Let it sit for at least 15-20 minutes or even longer for tough stains. Wipe away the paste with a damp cloth or sponge. For stubborn areas, you can use a non-abrasive scrubber. You can also try using white vinegar or cleaning vinegar: Equal parts vinegar and water in a spray bottle can be used after the baking soda paste for a final clean. Don't forget to check your manual on how to properly clean the glass door on your range before you proceed.
