Samsung Gas Range NX60T8711SS/AA
(Topic created: 05-06-2024 09:01 AM)
userORDKx5Fsu3
Kitchen and Family Hub
the ignitor switch keeps going out on my gas range. I just had it replaced November 2023 and now i cam back to the same problem 6 months later.  is there a recall on this product?  I need to know the part number of the ignitor so that i can order it.
Samsung_Moderator
Hello! Thank you for reaching out! I see how this can be frustrating with your oven not heating. I would recommend looking at our part's website samsungparts.com. You can also call our part's distributor at 1-800-627-4368.
1 Reply
Samsung_Moderator
