Cable connections or TV issue?
(Topic created: 08-17-2024 03:48 AM)
JROGERS1965
LED and OLED TVs
I have a 43" 4k UHD Smart tV.  It's probably about 4 or 5 yrs old. The picture has recently started going wonky on startup. Problem lasts about 5 or 10 minutes, then everything is ok. Is it a cable connection issue or the TV itself?453548513_7999979660056884_2612923684418079617_n.jpg
GaryB82
Galactic Samsung Care Ambassador
LED and OLED TVs
The only way to see if it's a cable issue is to try a different cable. If it still happens, it would be a port issue, and the tv would need to be serviced and / or replaced
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
GaryB82
LED and OLED TVs
JROGERS1965
LED and OLED TVs
I meant from the cable box.  I turned on the tv this morning without the box (TV+) and tried my Netflix account, and it still did it for about 10 minutes before stopping
Noobie
Comet
LED and OLED TVs
Yea I think it's the TV.
EvilMadness
Galaxy
LED and OLED TVs
Time for a new tv :television:....
