HDMI Not Permitted with Tivo
(Topic created: 07-05-2024 07:04 AM)
sparklez867
LED and OLED TVs
I have a Samsung UN65K6290FXZA and I am frequently getting "HDMI not permitted" when I am watching through my Tivo Edge box  . My Apple TV works fine and I actually get audio  (even with the error message displayed) -- but no picture. Through a mixture of unplugging the HDMI cable and moving it to another input, turning off the TV, switching to a new cable, it comes back after 15 min of annoyance. I' not even sure which one ends up solving it.   Is there anything I can do to avoid this?
bill-e
Cosmic Samsung Care Ambassador
LED and OLED TVs
That cable should work.
** If my response helps, please click on Like (Heart). If I resolved your issue also please click on Accept as a Solution so that others can benefit.
Bill
Galaxy Fold 6 512g(VZW), Galaxy Book (original, VZW), Tab S8 Ultra, Tab S4, Galaxy Watch7Ultra(VZW),Galaxy Watch6Classic 47mm(VZW), M8 Smart Monitor, NEO 55" QN90D TV, Buds Pro
SMASNUG100
Galaxy
LED and OLED TVs
https://tivoidp.tivo.com/tivoCommunitySupport/s/article/DVR-is-Displaying-Viewing-is-Not-Permitted-T...
If you see "Viewing is not permitted using the TiVo Digital Media Recorder's HDMI output. Try another TV input..." or a similar message, it means that the TiVo device is not receiving an HDCP key back from the television. To comply with the HDMI copy protection standard, the TiVo device must receive an HDCP (High-Bandwidth Digital Content Protection) key back from the television before it can decode the signal and allow you to view or record programming.
sparklez867
LED and OLED TVs
Hey thanks for your help. I actually tried that first and it doesnt seem to immediately work.  I have to turn the tv on and off, use different cables, and just wait it seems. From a bit of online research, I read that some people have had luck using an HDMI splitter..it seems so odd that that would work. I’d think that would be harder to get the signal since it’s making a stop first at the splitter? Thanks again for helping me, I struggle  with this stuff!
SMASNUG100
Galaxy
LED and OLED TVs
You might want to try a different cable too. The really really cheap ones don't have computer chips And instead the wires are just directly connected to both sides and that can cause the data connection to break
sparklez867
LED and OLED TVs
I bought a 4K one  and I thought that solved it, since I had no errors for two weeks, but then I got the error message again yesterday. I bought the Highwings HW-8K-2M-001. Cable. Would you consider that a good one?
Samsung_Moderator
LED and OLED TVs
Hi @sparklez867!  We appreciate you reaching out to the community.  The television isn't 8K compatible, so it may not work the way that you're hoping.  Your best bet would be to purchase one from samsungparts.com to promise compatibility.  Here is the link to them:
https://samsungparts.com/search?q=HDMI%20cable
If you have any additional questions, don't hesitate to reach back out to us!
sparklez867
LED and OLED TVs
Hello! The one I bought said it's both 8K and 4K compatable. Would it still not work properly?
If not, is there a particular cable from the Samsung store  that would work best? The model number is UN65K6290FXZA .  THANKS!
bill-e
LED and OLED TVs
Bill
sparklez867
LED and OLED TVs
Thank you!
