M5300 HDTV not connecting to the internet
(Topic created: 09-25-2024 08:13 AM)
userCenutcHdeq
LED and OLED TVs
I have a M5300 HDTV not connecting to the internet consistently.  I use to connect wirelessly but that only works occasionally now.  It has connected wired using a repeater for the connection but that does not seem to work now.  I can connect using an attached FireTV stick.
Obviously the best way for it to connect is wirelessly.
Any ideas as to how I can fix this.  Thank you.
SamsungTam
Honored Contributor
LED and OLED TVs
Hello! @userCenutcHdeq  Thank you for posting about this. Can you restart your TV router? sometimes, a simple restart can help refresh connections. Also, Ensure that your TV is running the latest firmware, as software updates often contain fixes for network-related issues. Last resort you can try to factory reset the TV.  Here is a link you might find helpful: https://www.samsung.com/us/support/answer/ANS00077524/
If the issue persists I recommend getting a
service technician have a look. As we would like to gather additional information and look at this on a case-by-case basis, please provide the device's full model code and serial number and your best contact phone number, name, and email.
Send a message on Facebook
Send Message on Twitter
Send Message to Moderator
If your unit is out of warranty and you would like to receive quotes on service/labor from an Authorized Service Center near you, please visit:http://www.samsung.com/us/support/service/location
opq9
Halo
LED and OLED TVs
Try force restarting the TV
userCenutcHdeq
LED and OLED TVs
opq9, if by you saying "force restarting" you mean unpluging and then replugging in the TV, or pressing the start button until the TV restarts, I have tried these a number of times and they don't seem to do the trick.  Thank you.
opq9
Halo
LED and OLED TVs
Try restarting your router or modem then
userCenutcHdeq
LED and OLED TVs
I have restarted my router, and my router is my modem. Thank you.
userCenutcHdeq
LED and OLED TVs
It just connects wirelessly for a while and then disconnects, and I fish around to fond something that woks
opq9
Halo
LED and OLED TVs
Then your TV just might be defective
meself
Honored Contributor
LED and OLED TVs
You think
opq9
Halo
LED and OLED TVs
I got this samsung a25 phone and believe me when I say this thing can not connect to a single thing outside my home my cellular data really doesn't work
SamsungTam
Honored Contributor
LED and OLED TVs
