- Mute
02-19-2025
05:53 PM
(Last edited
03-06-2025
05:27 PM
by
SamsungCaleb
) in
I have a UN55HU9000 Tv with a SEK-4500 evolution kit from 2018 connected. When I try to install the Max app I get this error message and it doesn’t install. The other apps like Disney Plus and Peacock Tv are working.
Solved! Go to Solution.
- Mute
02-23-2025 11:01 AM in
LED and OLED TVsUnfortunately, I would be unable to assist with updates as we only do troubleshooting. As for the other person they may have had the app installed before support was dropped. As Max would have dropped support for this I would recommend reaching out to their support forum for more information.
- Mute
02-20-2025 12:13 PM in
LED and OLED TVsHello! Thank you for reaching out! Can you install another app? Also, have you reached out to max support as this may be a compatibility issue as max pushes out more updates support for older devices even the evolution kit can and will sometimes be dropped.
- Mute
02-20-2025 02:21 PM in
LED and OLED TVsYes I can install other apps. This person on AVS forums has the same set up tv I have and his Max app works. Is there an update that you guys can provide for the SEK 4500 because it has not had an update since 2018?
- Mute
