- Mute
‎05-25-2024 05:23 AM in
LED and OLED TVsHi please can you help with this
ps4 was working fine. Now switch on ps4, Samsung tv recognises it . Click on icon. PS4 image comes up- they goes black and can’t connect
ive changed hdmi ports, tv software up to date, swapped to new hdmi lead , done hdmi troubleshooting and it says no problem with hdmi lead - arghhh - what is going on
Solved! Go to Solution.
- Mute
‎05-30-2024 09:34 AM in
LED and OLED TVsHi @Neilppp! Thank you for reaching out. It sounds like you may need to reset the resolution on your PS4. in order to do that you'll need to follow these steps:
While off, press and hold the power button on PS4, passed the first beep, and release after the second beep.
Then select 2. Change resolution.
This should get you on your way. If not, let us know and we can look into other troubleshooting, but more than likely, this will get you right. Don't hesitate to come back if needed.
Thank you for being a Samsung customer!
Be sure to click " âś“ Accept as Solution" when you find an answer that works for you.
- Mute
‎05-25-2024 07:30 AM in
LED and OLED TVs- Mark as New
- Mute
‎05-25-2024 09:27 AM in
LED and OLED TVs
- Mute
