QN65 Q80 4k Smart TV: how to reduce # of remotes (now need 1 for cable box, one for smart apps and 1 for sound bar
(Topic created: 07-12-2024 08:54 AM)
BocaMike
LED and OLED TVs
need to control vizio sound bar with tv remote, but when attach optical cable and select optical as sound source, then seems only way to control volume is using Vizio remote. Can't determine if other audio ports are available on rear of TV.... perhaps there is an alternate to optic connection.  Anyone know?  Is there a suggested universal remote I should consider to combine all 3 used now, into a single remote?
PS  I'm using ATT U-Verse set top box.
Thanks.
bill-e
Cosmic Samsung Care Ambassador
LED and OLED TVs
Try setting up the Samsung universal remote fiirst
https://www.samsung.com/us/support/answer/ANS00089902/
** If my response helps, please click on Like (Heart). If I resolved your issue also please click on Accept as a Solution so that others can benefit.
Bill
Galaxy Fold 6 512g(VZW), Galaxy Book (original, VZW), Tab S8 Ultra, Tab S4, Galaxy Watch7Ultra(VZW),Galaxy Watch6Classic 47mm(VZW), M8 Smart Monitor, NEO 55" QN90D TV, Buds Pro
LED and OLED TVs
Hard to know exactly without specifics of models etc, but by and large HDMI allows some controls of connected appliances (via the HDMI-CEC function).
Might be an option to see if that works for you?
bill-e
LED and OLED TVs
Bill
