Samsung 8 Series 55” TV unable to open the menu and unresponsive background window
(Topic created: 01-20-2025 09:34 AM)
DashiBilali
LED and OLED TVs
I’m having an issue with my Samsung 8 Series 55” TV. When I press the button to open the settings menu, nothing happens. Additionally, there seems to be a window in the background that is also unresponsive. Can anyone assist me with this problem?
SamsungTam
Honored Contributor
LED and OLED TVs
I recommend letting a service technician have a look. As we would like to gather additional information and look at this from a case-by-case basis, please provide the full model code and serial number of the device as well as your best contact phone number, name, and email.
Send a message on Facebook
Send Message on Twitter
Send Message to Moderator
If your unit is out of warranty and you would like to receive quotes on service/labor from an Authorized Service Center near you, please visit:
http://www.samsung.com/us/support/service/location
3Fees
Neutron Star
LED and OLED TVs
Faulty remote, tv's input source is not correct, or software glitch. Contact Samsung support.
Cheers
3Fees
DashiBilali
LED and OLED TVs
Thank you for your answering 🙏
DashiBilali
LED and OLED TVs
I haven't solved my problem yet.
SamsungTam
Honored Contributor
LED and OLED TVs
Hello! @DashiBilali  Thank you for posting about  this.  Does the window is in the background show anything like an error code? If possible check your remote to ensure that the batteries are not the issue. If you're using a universal remote, ensure that it's properly paired with the TV. Also, check the tv for updates. You can access the menu after restarting go to Settings> Support> Software update and check for updates.
If the above steps don't work, you can perform a factory reset: Press Settings> General> Reset or Support> self diagnosis> reset on the remote
Please let me know if this helps
DashiBilali
LED and OLED TVs
Thank you for your answer, I have done all of what you mentioned but the problem is I haven't access to the settings menu because it didn't show in the display, When I press the button to open the settings menu, nothing happensIMG-20250117-WA0002 (002).jpg
Samsung_Moderator
LED and OLED TVs
Can you try a power cycle on the TV and try from there? Also have you tried the remote on the SmartThings app?
DashiBilali
LED and OLED TVs
Yes, I did, in my case, the setting dialog box doesn't appear on the screen when I press the settings icon.
SamsungTam
Honored Contributor
LED and OLED TVs
