Smart view not working
(Topic created: 11-12-2023 04:22 PM)
userdgc3Zrimbq
Cosmic Ray
LED and OLED TVs
Stopped working. Tv doesn't show I tried everything .I even got it to work once and then it disappeared again
JUMP TO SOLUTION
Not applicable
LED and OLED TVs
Your currently running the latest version of the Samsung Smartview App! Please tell me when you starting experiencing the issue with not being able to successfully connect to your television?
userdgc3Zrimbq
Cosmic Ray
LED and OLED TVs
About 2 weeks ishhhh ago
userdgc3Zrimbq
Cosmic Ray
LED and OLED TVs
And the smartview function is greyed out on smart things...I got it to work once but I have no clue what I did.
Not applicable
LED and OLED TVs
On your Samsung Television Remote (Press and hold the Power Button) until the Television restarts
userdgc3Zrimbq
Cosmic Ray
LED and OLED TVs
Tried that before also..but did it just now
Not applicable
LED and OLED TVs
1. Unlug the Television from the A/C Outlet
2. Unplug all Connected Devices from the Television (Ie: HDMI, Component, USB etc)
3. Leave the power off and all devices disconnected from the Television for (5-10) Minutes
4. Plug the A/C Power Cord back into the Television
5. Try connecting to your Television with Samsung Smartview
6. Your Television needs to be set to Live TV
Once you have completed these steps please post your findings here.
userdgc3Zrimbq
Cosmic Ray
LED and OLED TVs
Didn't work. Tried that before also woth the Samsung rep..but gave it another go
Not applicable
LED and OLED TVs
The next step I want you to try is Tap and hold the Smartview Button. Go into Application Info and check the Permissions. Tell me what it says under Permissions: Also be sure the slider for "Remove Permission if App is Unused" is OFF
userdgc3Zrimbq
Cosmic Ray
LED and OLED TVs
Allowed nearby devices and notifications...and yes the slider is off
Not applicable
LED and OLED TVs
On the Smartview Application Info: Tap Force Stop Then Under Storage in the Smartview Application Info: Press CLEAR DATA
Then exit Smartview Application Info
