Supported Audio Formats for Samsung OLED S90D TV
(Topic created: 01-28-2025 03:30 AM)
SamuraiSunJio
LED and OLED TVs
Dear Samsung Support Team,
Recently, I attempted to play a movie file via a USB drive on my S90D TV. The movie had an audio track encoded in DTS-HD MA 6ch 2787 kbps, but the TV was unable to play the audio. This has left me concerned about compatibility and the full range of audio formats supported by the TV.
Could you please provide me with a comprehensive list of all audio formats supported by the Samsung OLED S90D TV? Additionally, I would appreciate it if you could clarify whether the TV supports DTS-HD MA or other DTS audio formats, either natively or through a firmware update.
Understanding the supported formats will help me ensure that my media files are compatible with the TV and avoid similar issues in the future.
Thank you in advance for your assistance.
BrüZZi
Supernova
LED and OLED TVs
Samsung dropped DTS support on 2018  and newer TVs.
Oxford
Honored Contributor
LED and OLED TVs
Sorry, this is a user to user Forum with limited actual Samsung participation. You may not get what you're looking for here. I can't really suggest where to go, hopefully somebody can.
BrüZZi
Supernova
LED and OLED TVs
LED and OLED TVs
DTS codecs are not supported by Samsung TVs, as BrüZZi correctly pointed out, DTS was abandoned in 2018.
Here is the list of video and audio codecs that are supported by Samsung TVs.
https://en.tab-tv.com/list-of-video-and-audio-codecs-supported-by-samsung-tvs/
