- Mute
ā06-16-2024 10:39 AM in
LED and OLED TVsGreetings,
I have a Samsung QN90AA 50 Tv and YouTube TV. Up until last night it had worked for some years.
Now there is no video or sound. The guide shows up and all the settings tabs and so on. There is even the option to resume a previously viewed show and I can click on that.
No video at all. It is stuck on a black screen with the little circle spinning.
If I click on the resume show windows, there is a commercial for some 3 minutes. The commercial video shows. No problem. there little timer is there to show the 3 minutes going by. Then upon completion, the screen goes black with the spinning circle.
I have done the following: power recycle, reinstall, clear cache, delete Smart Hub and reset to factory specs. No change.
In looking at the nerd information there is NO "Network Activity" The connection speed shows as well as the buffer health.
Also, YouTube TV works fine on my Samsung S21, desktop, laptop, tablet and Roku device. No problem.
The Samsung TV is connected via hardware to the router. There is WiFi also. Tried both connections. Just in case there was a hard wire issue. Zero luck there.
Up until now, there was not any issue. Download speed is about 120 Mps and upload is about 60 Mps.
- Mute
ā12-08-2024 08:01 AM in
LED and OLED TVsJust to add an interesting finding. I can watch YouTube TV on my Samsung phone. No problem at all. When I try to stream YouTube YV to my TV with the Samsung link, I do not get any live video stream. Not on the TV nor on the phone. Break the connection with my TV and voila! streaming is back on the phone.
I really do think it is a Samsung issue but they will not have anything to do with my calls or emails. I keep getting referred back to YouTube TV. At least YouTube TV is listening to me although there is no solution anywhere.
- Mute
ā12-18-2024 06:03 AM in
LED and OLED TVsThe only successful work-around I could find is to remove all the 3rd party apps on my Samsung TV and use a $25 4K Firestick or some other streaming device (i.e., Roku). Everything works again using the Firestick.
I had the same issue on my 13 month old, 2023 Samsung QN75QN90CAFXZA. After a year, both Youtube TV and Paramount Plus just stopped working with the same symptoms I see in this thread. I ran through all the technical troubleshooting steps I could find, and likely a few more tests than what I've seen suggested here over a period of 4 frustrating weeks.
After speaking or chatting with multiple companies involved, the ping pong match was in full swing. The App guys pointed to Samsung, and Samsung pointed to the Apps guys, and we get nowhere. I even had Samsung Support remote in to test my TV, but they couldn't find anything wrong.
This whole experience makes me think I should have purchased a less expensive brand TV and just use an Amazon Firestick.
- Mute
ā12-18-2024 06:47 PM in
LED and OLED TVsI wonder if Sony or one oof the other brands has the same issue or is it related to the Tizan OS
- Mute
ā12-10-2024 04:08 PM in
LED and OLED TVsMy QN90AA TV was updated to 2220.9 recently but still no change with any of the broken apps.
- Mute
ā12-10-2024 05:49 PM in
LED and OLED TVsWas this an automated update?
- Mute
ā12-10-2024 10:48 PM in
LED and OLED TVs> Was this an automated update?
Yes, that's why I missed that it had been done.
- Mute
ā12-21-2024 03:54 AM in
LED and OLED TVsMy streaming issues started with YTTV at first and I tried everything others shared in this feed, including a factory reset. Opened a Ticket with YTTV Support and just shared a bunch of info but got nowhere. Finally noticed the Disney, Hulu and Peacock apps werenāt streaming now (Netflix and Prime Video worked fine). Called Samsung Support and after some checks with remote access they determined they needed to have a tech come out (TV was under warranty). Tech said the mainboard had to be replaced as theyāve seen this issue after the 2011 sw update. They replaced it and it reverted to the original sw and he told me not to auto update. To check for newer sw updates and confirm the update would resolve noted streaming issues. Not the ideal solution but wanted to share how they resolved the streaming issue on my TV. Works great now, as long as I donāt upgrade š¤¦š»ā:male_sign:
- Mute
ā12-21-2024 06:21 AM in
LED and OLED TVsGlad you're back up & running. Sounds like replacing the motherboard & turning off automatic updates worked for you. My concern going forward with that solution is you will no longer get any updates and some of those might security related.
Samsung should provide a way to manually remove the last update and go back to the one that worked while they work on a fix but I'm not holding my breath on that scenario actually coming to fruition. Samsung support already connected to my television and did not indicate they had the ability to do remove the latest update from their end either. So we'll just continue using the Amazon fire stick for all of our streaming.
- Mute
ā12-21-2024 07:18 AM in
LED and OLED TVsYou were much more successful than I was with regard to Samsung. They just steered me to the App vendor, i.e. YouTube TV.
The YTTV folks were very kind, but nothing was done.
It seems the only way to remedy this issue is for a new firmware upgrade that addresses the code problem or for a firmware downgrade. There is no way of which I am aware that can produce a downgrade other than a motherboard change with the old firmware.
It seems we have a cause.
It is the Samsung firmware that is the problem.
We just do not have a good solution.
- Mute
ā01-10-2025 07:39 AM in
LED and OLED TVsIāve been having the exact same issue with the Samsung YouTubeTV app since 1/1/2025. I was on firmware 2011 and noticed today my S90 had auto updated to version 2020. Unfortunately even reinstalling YouTubeTV after the update and a power reset did not fix the issue. Is there any hope that a future update is planned to resolve the issue?
