- Mute
ā05-01-2024
09:42 PM
(Last edited
ā05-03-2024
02:02 PM
by
Samsung_Stephan
I got odyssey G8 just 1 months ago. I have been noticing various issues. I have MacBook and windows laptop which I connect using thunderbolt. There is audio delay which is quite normal but it can be rectified by switching sources or restarting monitor.
I built a new PC using RTX 4070 it was working fine but sometimes there's no display on DP occasionally and it even doesn't recognize it. Sometimes it will just say unsupported resolution. It worked with HDMI though but that to on low refresh rate. When I connect my laptop/mac using thunderbolt PC display is not visible completely.
On PS5, the video resolution is locked till 2k but it does show the option for 4k (which is disabled).
I see there is no issue with the laptop or PC and other Samsung monitor owners have same complain.
- Mute
ā05-03-2024 06:08 AM in
Monitors and MemoryDid you read your User Manual to see which compatible resolutions/refresh rates can be used by the PS5, PC, and Mac to display properly on the G8?
- Mute
ā05-03-2024 11:37 PM (Last edited ā05-03-2024 11:39 PM ) in
Monitors and MemoryThe manual doesn't have anything for PS5 also PS5 doesn't show option if that isn't supported here it shows but is disabled. Mac always works fine but when I connect it will freeze it didn't happen on by odyssey g7 ever. Even after it connects there's a sound lag for which I need to turn off monitor and switch between speaker options to make sure it's working properly.
Also please re-read the issue before directly saying something this. It makes us look look stupid and refrain from posting our issues.
- Mute
ā05-04-2024 04:35 AM in
Monitors and MemoryThe PS5 resolutions are designed for TV displays so you have to be sure the one you choose is acceptable to the G8.
![](/skins/images/58395F307013B0F94C185F957C761EAB/responsive_peak/images/icon_anonymous_message.png)
