- Mute
07-06-2021
12:42 PM
(Last edited
07-19-2021
02:05 PM
by
SamsungJoJo
) in
I have a Note 20 Ultra 5G. I purchased the Verizon version from Samsung. Verizon updates block some software features like "Call & text from other devices" - "Update Security Engine" - "Device Protection" etc. After 2 months Verizon is supposed to "Unlock" the phone. Is there any way to update my "Unlocked phone" with these software features??
Solved! Go to Solution.
- Mute
07-06-2021 01:23 PM in
Note20@OldTechi To unlock your phone you will need to request the unlock code from Verizon and follow the procedure that they provide.
Unfortunately even after you get it unlocked you may not have those features available since your phone has the Verizon firmware installed.
- Mute
- Mute
07-09-2021 03:41 AM in
Note20- Mark as New
- Mute
07-07-2021 12:40 PM in
Note20contact verizon, they should be able to help you
