- Mute
08-12-2019 06:24 PM (Last edited 08-12-2019 06:48 PM ) in
Projectors & Other TVsHello.
Looks like I just fell into the same Remote ‘flashing red, not pairing, not available, tv turning on by itself in the middle of the night’ black hole I’ve seen posted about. How frustrating! I have read through the posts and tried everything, yet i cannot get any of the functions to work. Everything has worked perfectly for over a year. I’m so confused, please help.
I have UN65KS9500FXZA.
Solved! Go to Solution.
- Mute
07-05-2020 10:07 AM in
Projectors & Other TVsThere are no buttons on the TV.
![](/skins/images/E0FC46DE9F90A2C7AE42CE054949782E/responsive_peak/images/icon_anonymous_message.png)
- Mute
07-05-2020 10:22 AM in
Projectors & Other TVsAre you located in the US? Most televisions have a toggle button at the bottom either in the middle or one of the sides.
- Mute
07-05-2020 10:30 AM in
Projectors & Other TVsI found it! Software verion 1280
- Mute
07-05-2020 10:51 AM in
Projectors & Other TVsThe software is up to date, when was the unit purchased?
- Mute
07-05-2020 11:05 AM in
Projectors & Other TVsAbout two-three years ago, I can't remember where I bought it from.
- Mute
07-05-2020 11:08 AM in
Projectors & Other TVsYou can try a replacement remote from SamsungParts.com
If this does not work, the next step would be service.
You can find a local repair center here: Link
- Mute
07-05-2020 11:10 AM in
Projectors & Other TVsOk, thank you for your help.
- Mute
07-05-2020 11:09 AM in
Projectors & Other TVsIs it possible for you to look up when I created this account? That may be the year. Although, I've had and have several Samsung TVs of varying ages.
- Mute
07-05-2020 11:34 AM in
- Mute
07-21-2020 08:54 PM in
Projectors & Other TVsPlease help me, my remote is not working 😞 . It's a Samsung TV with a Samsung remote bought at best buy in January 2020. Model Q60 R.
