How to connect wireless headphones
(Topic created: 04-12-2025 05:27 PM)
SMcD
QLED and The Frame TVs
How can I connect my headphones? There is no plug like in the old tv.
Samsung_Moderator
Hello! Thank you for reaching out! Please also know that not every pair of Bluetooth headphones can connect to the TV. You can also use the link below to help set this up.
https://www.samsung.com/us/support/answer/ANS00085342/
realaud
Honored Contributor
If your TV is Bluetooth capable, you would pair your headphones as with any other device. I am sure your TV has settings where you can do this. But, again, your TV must have Bluetooth.
Please mark any response that helped you as your solution.
Samsung_Moderator
