Solar remote battery status
(Topic created: 08-01-2024 05:09 AM)
Real doc
QLED and The Frame TVs
How to check the solar battery status on 8K tv
Samsung_Moderator
Hi there, Thanks for asking! I found this helpful information in our guide on charging the solar remote (linked below).
If the LED stays on for at least 5 seconds after you press a button on the remote, this means that the remote's battery needs to be charged. A charging guide will appear on the TV screen once the remote's battery level is at 50%, then again at 10% or less.
Note: The remote control's LED will stay on for 5 seconds every time a button is pressed when the remote's battery is at 10% or less.
If the LED is staying on, this means that the remote is charging successfully. The LED will turn off once charging is complete.
https://www.samsung.com/us/support/answer/ANS00088862/
Samsung_Moderator
bill-e
Cosmic Samsung Care Ambassador
Settings->General and Privacy->Power Saving Settingd->Solar Battery level
this is off the.top of my head but should get you close
** If my response helps, please click on Like (Heart). If I resolved your issue also please click on Accept as a Solution so that others can benefit.
Bill
Galaxy Fold 6 512g(VZW), Galaxy Book (original, VZW), Tab S8 Ultra, Tab S4, Galaxy Watch7Ultra(VZW),Galaxy Watch6Classic 47mm(VZW), M8 Smart Monitor, NEO 55" QN90D TV, Buds Pro
