Help my dryer is becoming thumper
(Topic created: 01-07-2025 08:05 AM)
Twing
Washers and Dryers
Hi I'm new here cuz I just got my washer and dryer set last night hooked it up did a load this morning wash your works beautifully dryer thumped and had a slight foul odor. The thumping honestly sounded like tennis balls or a pair tennis shoes inside the dryer. Neither we're in there. So I ran the code, the code said that there was clothes in the drum I checked was nothing inside the drum. We ran the code still said that there was closed inside the drum. I did a vent clean nothing was there. And now I am out of suggestions for myself. Has this happened to anybody else does anybody have any suggestions for me maybe
GaryB82
Galactic Samsung Care Ambassador
Washers and Dryers
Sorry to but since you done a lot that is listed to do on the first page I’m listing below you would need to contact support and have a tech check it out
https://www.samsung.com/us/support/service/locations/
If you've found my post to be helpful, Please like my Comments āœ“āœ“āœ“.
If my response resolved your issue, please press the Like and āœ“āœ“āœ“ to Accept as Solution button.
Samsung_Moderator
Washers and Dryers
Hello and thank you for reaching out to the Community regarding the noise concern. The dryer is absolutely not suppose to operate as such, with loud "thumping" sounds. We strongly recommend stopping the usage of the dryer IMMEDIATELY to prevent any physical damage that can occur. We also encourage you to contact the installer and/or the retailer and have the dryer thoroughly inspected before resuming use.
Furthermore, we, moderators, are here to assist regarding this matter, and you can private message us by clicking on the chat option with your full model and serial number to proceed.
