Galaxy Book 2 won't charge or power on. (Blue light blinking)
(Topic created: 05-31-2020 08:35 AM)
userP3Y16B23RO
Computers
I have been having trouble with my Galaxy Book 2. It will not power on as of last night. When I originally started to charge it, it showed 1% charge. I left it on the charger for an hour and it still had 1% charge. I unplugged the charger and plugged it back up only to see no charging indicator and the blue light flashing. I held the power button down for a total of thirty seconds. I then did the same with the power and volume down button several times. I then repeated the cycle this morning and still no results.  Any other suggestions?
SamsungLarry
Computers
Hey, give this link a shot: https://www.samsung.com/us/support/troubleshooting/TSG01109643/. If this does not help I recommend letting a service technician have a look. Send your full model code and serial number via private message or call 1-800-SAMSUNG directly to get started.
SamsungLarry
Computers
userosHY9TpZJE
Computers
did you already have it fixed? mine doesn't turn on as well. no blinking lights at all. when plugged in , it only shows the battery indicator level, and still doesn't turn on
uservNbeopVYSg
Computers
Did u ever get it figured out? Mine is doing the same thing.
Not applicable
Computers
@uservNbeopVYSg    We are sorry to hear about this. Please send the full model and serial numbers to this PM Link.
Bumblecat
Computers
this is worst device
Bumblecat
Computers
Galaxy Book 12 is not booting up.
userdSHr0J2M1s
Computers
is there any solution for this problem? my device has same problem
NoelPMaguire
Computers
Unfortunately I have the same issue. I brought it to a local Samsung Repair Store and they said they don't look at tablets or laptops. I refuse to believe after the initial cost of these that Samsung will not accept even looking at it?
