- Mute
‎11-11-2017 12:51 PM in
Galaxy Note PhonesSolved! Go to Solution.
- Mute
‎01-26-2018 11:03 AM in
Galaxy Note PhonesMe too!
- Mute
‎09-06-2018 12:25 PM in
Galaxy Note PhonesModel SM-M95OU
Serial # R38JA02VAER
IMEI 351823091486605
AT&T
- Mute
‎09-28-2018 02:07 PM in
Galaxy Note PhonesJust try cleaning the speaker on top with a toothbrush or blue tac it will work.
- Mute
‎09-06-2018 12:31 PM in
Galaxy Note PhonesAdd baseboard version
N95OUSQS5CRG9
- Mute
‎03-06-2018 10:42 PM in
Galaxy Note PhonesI'm having the same issue. I called Samsung but during the troubleshoot call was disconnected and the REP never called back. She advised to reset to factory setttings. I've to backup my data before i can do that. But my phone is 2 months old why is this issue coming. I'm a die hard fan of Samsung but with this My trust is shaking on Samsung. 😞
Please help or advise if possible.
- Mute
‎03-26-2018 05:07 AM in
Galaxy Note Phonesmake sure u backup date and can get it back or transfer it to another device i could not get my backup but my phone is now working did factory reset and now volune works. i will be trying it out with diffrent apps i had one at a time till i find it mine was like it from day one lunch i trancferd all my stuff from a s3 so coould have been just that
- Mute
‎05-03-2018 04:57 AM in
Galaxy Note PhonesUse a bit of peroxide on a cotton tip or brush or alcohol wipe and clean the ear speaker. The download a clean speaker app in play store. It will fix it instantly
- Mute
‎05-03-2018 04:59 AM in
Galaxy Note PhonesIt's the top ear speaker. It needs to be cleaned as it gets a layer over it pretty quick. I used peroxide of a brush and gently cleaned... then used a speaker cleaning app from play store. Worked instantly
- Mute
‎08-11-2018 07:54 AM in
Galaxy Note PhonesI have a hard time getting what someone says whem am on a call. I have started considering switching to iphone.
- Mute
‎08-12-2018 05:43 PM in
Galaxy Note Phones@useroTzs2ffSeC; Hey, give the troubleshooting steps below a shot and let us know if they resolve the issue. Just click on the links below to access the full articles.
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=710174&modelname=SM-...
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=710176&modelname=SM-.
