Note 8 in call volume low
(Topic created: 11-11-2017 12:51 PM)
usera3kLtCJUoT
Galaxy Note Phones
Tried clearing cache Tried factory reboot Re installed SIM card Restarted in safe mode Still no change and extremely low call volume
JUMP TO SOLUTION
userRizLKTA9dU
Galaxy Note Phones
Simply hold a fine needle and try opening the pores of speaker grill delicately. Then clear  it with a dry toothbrush. It worked for  me. You may need a lense to zoom in 😁.
CrazyCatDad
Galaxy Note Phones
i did everything
PhonusQuaver
Galaxy Note Phones
I used a refillable compressed air can spraying at an angle and the volume is back to normal.
userFTBoJmgxpB
Galaxy Note Phones
I gently used a needle around the opening. I then wiped it down with an alcohol wipe. That didn't work until I did all that again and ended with a toothbrush like several said to do. Sound is back and I can have an actual conversation with privacy. So thankful for the advice.
user8E6DmzxIlI
Galaxy Note Phones
Had the same problem. But the advantage of this phone is I can smoothly play my favourite league of legend game on this.
Members_i9O0mRi
Galaxy Note Phones
SamsungJace wrote:
Give this a shot;
Go to Settings>Apps>Click on the three dots at the top right corner>Show system Apps>Phone(All three)>Storage> Clear Cache/Data
Go to Settings>Apps>Click on the three dots at the top right corner>Show system Apps>Speaker detector>Storage> Clear Cache/Data
Let me know how this works for you.
This worked like a charm! I was afraid of losing contacts and such so i backed up my phone first to my7 computer. but it didnt cause any loss of contacts or call history
