- Mute
‎11-11-2017 12:51 PM in
Galaxy Note PhonesSolved! Go to Solution.
- Mute
‎11-27-2018 02:12 AM in
Galaxy Note PhonesClean your ear speaker with fine short bristle brush and blow with compressed air and you'll be good.
- Mute
‎07-02-2020 12:26 PM in
Galaxy Note PhonesDoesn't work for me, still can't hear. Have to use loudspeaker.
- Mute
‎03-07-2018 10:04 AM in
Galaxy Note PhonesI'm experiencing the same issue. I think there is something internally wrong. I spoke with tech support regarding this issue they say I will have to send my phone in for further evaluations after I tried multiple things with them via phone. Ultimately, hard resetting the Note 8. Little upset to be experiencing this issue and only had the phone about 6 months.
- Mute
‎03-13-2018 09:14 AM (Last edited ‎03-13-2018 09:21 AM ) in
Galaxy Note PhonesI also experienced low in call volume on my note 8. What I did is I used electric toothbrush to clean the speaker at the top of the screen and it solved the problem. Now I can clearly hear properly when i have a call. I hope it helps thanks.
*Maybe the cause of my low call volume is due to the glue i used when I installed my domeglass tempered.
- Mute
‎03-14-2018 02:26 PM in
Galaxy Note PhonesAll I can say is Wow.
Toothbrush trick did the job. Days of searching for a answer and on the verge of sending the phone back and it comes down to an electic toothbrush
Thanks for making the post
- Mute
‎03-14-2018 06:43 PM in
Galaxy Note Phones- Mark as New
- Mute
‎06-25-2018 10:28 AM in
Galaxy Note PhonesI know speaker on bottom is, where is the one for hearing
- Mute
‎03-19-2018 09:53 AM in
- Mute
‎03-24-2018 08:03 AM in
Galaxy Note PhonesYes just the tootbrush. Used it for about 3minutes or more until you see if there is some changes
- Mute
‎06-27-2018 10:21 PM in
Galaxy Note Phones
@MARC0HH wrote:I also experienced low in call volume on my note 8. What I did is I used electric toothbrush to clean the speaker at the top of the screen and it solved the problem. Now I can clearly hear properly when i have a call. I hope it helps thanks.
Lol omg I can't believe this worked! Thank you. I also used a speaker unclogger app.
