- Mute
‎11-11-2017 12:51 PM in
Galaxy Note PhonesSolved! Go to Solution.
- Mute
‎07-07-2018 03:34 PM (Last edited ‎07-07-2018 03:36 PM ) in
Galaxy Note PhonesThe electric toothbrush trick worked for me as well. Didn't even have to th speaker unclogger app.
- Mute
‎07-18-2018 08:51 PM in
Galaxy Note PhonesSimilar problem. Cleaned the top speaker grill with my electric tooth brush and I solved the issue.
- Mute
‎07-18-2018 08:53 PM in
- Mute
‎08-09-2018 10:40 PM in
Galaxy Note PhonesThank you so much! I was having the same issue starting a few days ago and tried the software stuff (all except factory data reset). Cleaning the speaker with a stiff brush did the trick!
- Mute
‎09-09-2018 08:01 AM in
Galaxy Note PhonesTrying this now, thanks. Did you use water?
- Mute
‎10-08-2018 02:57 AM in
Galaxy Note PhonesGreat... I also had the same issue and tooth brush trick saved me from spending Hundreds of Rupees. Thanks
- Mute
‎04-05-2019 12:56 PM in
Galaxy Note Phones
@MARC0HH wrote:
I also experienced low in call volume on my note 8. What I did is I used electric toothbrush to clean the speaker at the top of the screen and it solved the problem. Now I can clearly hear properly when i have a call. I hope it helps thanks.
*Maybe the cause of my low call volume is due to the glue i used when I installed my domeglass tempered.
JUST WAAAW !!!!
it really worked 😄
THANK YOU MAN
- Mute
‎04-30-2018 03:03 AM in
Galaxy Note PhonesThis has happened to me twice. First time I received a replacement Note 8. And now it has happened again. I'm waiting on my replacement for my replacement. What gives?
- Mute
‎05-01-2018 11:01 AM in
Galaxy Note Phones
What carrier is your Note 8 with? Also, before you decided to replace your Note 8, have you tried any of the troubleshooting steps already mentioned in the thread?
- Mute
‎05-02-2018 11:04 AM in
Galaxy Note Phones
Hello again, just thought I would reach out and see how you were faring. Did you still need assistance?
