- Mute
‎04-12-2021 12:10 PM in
Galaxy S21Solved! Go to Solution.
- Mute
‎04-19-2021 11:22 AM in
Galaxy S21I understand how frustrating this can be. For the double text messaging issue, try clearing the cache of the app. https://www.samsung.com/us/support/answer/ANS00077611 You can also try clearing the cache partition. (The steps for this vary by phone.) It is also recommended if you have multiple texting apps that you remove the excess apps as they could be sending the duplicated message. If these troubleshooting steps are not helpful and for the concern with not receiving incoming calls until they are missed, you will need to work with your service provider for additional assistance.
- Mute
‎04-12-2021 12:18 PM in
Galaxy S21- Mark as New
- Mute
‎04-12-2021 12:23 PM in
- Mute
‎04-12-2021 12:24 PM in
- Mute
‎04-13-2021 03:09 PM in
- Mute
‎04-12-2021 01:15 PM in
- Mute
‎04-12-2021 03:16 PM in
Galaxy S21do you have AT&T?
- Mute
‎04-12-2021 07:06 PM in
- Mute
‎04-13-2021 08:36 AM in
Galaxy S21have you contacted AT&T? I think this is AT&T's server issue. I'm sure the majority of users commented here are AT&T.
- Mute
‎04-13-2021 04:42 PM in
Galaxy S21
