- Mute
01-28-2024
05:28 PM
(Last edited
02-28-2024
11:13 AM
by
SamsungJoJo
) in
Always On Display drains nearly 2% of battery per hour on my S24 Ultra. This is much higher than the S23 Ultra. Hopefully this will be fixed in an update?
Solved! Go to Solution.
- Mute
02-16-2024 04:54 PM in
Galaxy S24- Mark as New
- Mute
02-16-2024 05:01 PM in
- Mute
02-16-2024 11:48 PM in
- Mute
02-21-2024
08:37 AM
(Last edited
02-21-2024
02:49 PM
by
SamsungJustin
) in
I experienced this. Can any expert weigh in on this issue please. The difference is significant.
- Mute
02-22-2024 03:50 AM in
Galaxy S24Hello guys, I’ve preordered and received my Samsung S24 Ultra on January, 31st. I’ve been using this daily ( not a heavy user, using apps like instagram, facebook, mostly YouTube ).
Since February, 1st till today ( already passed the Learning phase of the battery, because its already 3 weeks ) the Battery’s still weirdly drains quite fast, it’s noticeable. Like today, i didn’t open any Apps, Battery usage 5%, SOT 4m 😢
Already tried set it to light, adaptive, still the same.
Any advice? Thanks
- Mute
02-22-2024 07:05 AM in
Galaxy S24Same here man! Moved from pixel 4a, It's disappointing for such a flagship product. My present SOT is 47 percent consumption for 3h 15 mins of very light usage. Sucks.
- Mute
02-24-2024 09:29 AM in
Galaxy S24Hey guys, even after the newest patch Update from Samsung on february 24, it’s still the same for the battery. I think it got even worse. I tested the phone later after, on february 25.
I only used camera ( didn’t open any other app, just camera ) for taking a 2 or 3 pictures for 3 minutes and lost 2%, the first minute lost 1%. I checked the SOT menu, to see the camera app is 3 minutes and only used 0,9% ( which is a lie, i saw it drops with my own eyes and i’m not trippin for sure 😅 )
From day 1 till today, which is 3 weeks now, this new S24U and what so called long last battery, is getting on my nerves. 🥲
- Mute
02-23-2024 04:11 AM (Last edited 02-23-2024 04:12 AM ) in
- Mute
02-23-2024 04:26 AM in
Galaxy S24For me it's 15 percent per 1 hour of SOT. (before update). Will check post update
- Mute
02-23-2024 04:31 AM in
Galaxy S24How many days have you owned your device? The battery usually takes 7 days to learn your usage patterns, sometimes a bit longer. A major software update, like Android 15 (later this year) also resets your battery learning time, which you'll have to let it adjust after an Android update too.
![](/skins/images/310CA7901DBE912C9EF254269A0C54D3/responsive_peak/images/icon_anonymous_message.png)
