Galaxy S24 Battery Drain
(Topic created: 01-28-2024 05:28 PM)
GitDatPC
Galaxy S24
Always On Display drains nearly 2% of battery per hour on my S24 Ultra. This is much higher than the S23 Ultra. Hopefully this will be fixed in an update?
JUMP TO SOLUTION
Dfran1
Halo
Galaxy S24
Over 2 weeks now
Fcep22
Galaxy S24
Yeap, after the update, i noticed my battery was draining quicker for me, went from 98 to 90 in like 15 min, and my screen is dim , just checking settings and stuff. Not even watching Netflix with full brightness was my battery going down so fast
Jewelia
Galaxy S24
I too am having issues with my battery draining quickly.
harv134
Galaxy
Galaxy S24
You guys should wait for an update because samsung is probably making a patch for that error
mRnjauu
Galaxy S24
AOD uses around 15-17% per charge. Too high.
jmtrader1
Galaxy S24
Really disappointed with the battery life. Always on display kills the battery, and social media. Simple things shouldn't kill a flagship battery
FlushedRick
Galaxy S24
Hi all, please try the following; it did the trick for me. I just wiped the cache partition. (https://eu.community.samsung.com/t5/galaxy-s21-series/wipe-cache-partition/td-p/7688007)
The phone restarted, and et voila. It does last much longer than it did before. I am thrilled with the solution. You might want to give this a try. I hope it will work for you, too.
LeoWyatt89
Nebula
Galaxy S24
Hello, Welcome to the Community. We understand the concern of the battery draining quickly.
Some things that can help with Battery optimization, if you're just having a battery draining issue, is the following:
Note: The battery adaptive feature may cause the battery to drain a little faster at first until the phone adapts to your usage, and learns how you're operating, the charge will be stored and used in different manners based on how you use your phone. This sometimes can take a few weeks for it to learn the habits and customize itself to make sure you have the best performance and lasting battery.
https://www.samsung.com/us/support/galaxy-battery/optimization/
You can also try the steps here: http://www.samsung.com/us/support/troubleshooting/TSG01001388/
If you continue to experience the battery drain, we recommend having the phone evaluated by an authorized technician. You can use the following link to find a list of service centers in the U.S. that can do the repair: http://www.samsung.com/us/support/service/location or by calling customer support at 1-800-726-7864.
For service outside the U.S., please use this link: https://www.samsung.com/us/common/visitlocationsite.html
userIendZkKoqn
Galaxy S24
S24 ultra
My battery is draining so fast after the software update.
ArtDesk
Supernova
Galaxy S24
First, turn off autosync, put all apps you aren't using daily into deep sleep. Turn on datasaver and turn off autowifi. In datasaver, turns everything unnecessary to connect by wifi only, Turn Google location settings off. You can connect manually. That's the starter plan.
