Galaxy S24 Battery Drain
(Topic created: 01-28-2024 05:28 PM)
GitDatPC
Galaxy S24
Always On Display drains nearly 2% of battery per hour on my S24 Ultra. This is much higher than the S23 Ultra. Hopefully this will be fixed in an update?
JUMP TO SOLUTION
joeldf
Galaxy
Galaxy S24
I've never seen it that high on my phones. I have an S24+ now, and in the past 7 days, the highest it got was 9.4%. Normally, it averages 4 to 5%. And I have it always on - when I'm not using it that is.
Can't see what it does overnight because it's always on a wireless charger at night.
npmp
Galaxy
Galaxy S24
I've attached a screenshot of both AOD page and its version. Does anything look different from yours?1709432054863.jpg1709432054879.jpg
3Fees
Red Giant
Galaxy S24
Turn on power saving mode and see if that helps.
Cheers
3fees
Galaxy S24
This is why I NEVER use this. On none of my devices, S24 ultra, apple watch ultra or iPhone 15 Pro Max.
usertFx2jf0oHA
Galaxy S24
Had the phone for a month, can someone help? I've done literally all basic troubleshooting. Battery usage is at a copping 208%, with Google Play services consuming the most battery. What's causing this?!
neilth
Red Giant
Galaxy S24
Try booting the phone into safe mode and see if it works any better in that configuration. If it does, that would generally mean that you have some type of 3rd party software installed, causing your problem.
usertFx2jf0oHA
Galaxy S24
So it is from the software update. My carrier did a test in safe mode, and it is not the battery. @communityuser3e0eder FYI ASAP
usertFx2jf0oHA
Galaxy S24
Hmmm, wonder what the 3rd party is
userBqcNMldGxA
Galaxy S24
Thats just life with the exynos version my friend
Vegeta
Galaxy
Galaxy S24
If you have a that phone with the exynos chip that is problem it runs hot feel a life of it it can never get through the day half a day of charge when it's fully charged and it tends to overheat really bad I think he's the switch it out for the snapdragon you have a better chance with that version of the s24 ultra
