Galaxy S24 Battery Drain
(Topic created: 01-28-2024 05:28 PM)
GitDatPC
Galaxy S24
Always On Display drains nearly 2% of battery per hour on my S24 Ultra. This is much higher than the S23 Ultra. Hopefully this will be fixed in an update?
JUMP TO SOLUTION
Dawgedog
Cosmic Ray
Galaxy S24
Hi,
Anyone else experiencing battery drain with AOD on S24 ultra? I'm averaging anywhere from 7-10% drain per day, it's the top thing draining my battery.
Thanks
strangerzero
Galaxy S24
Yes I am facing the same, slept on 40% battery and after waking up saw my phone was dead
Dawgedog
Cosmic Ray
Galaxy S24
Specifically, is AOD draining your battery?
msgribble
Supernova
Galaxy S24
me too
Ibuddy66
Galaxy
Galaxy S24
Yuppers. But I don't even use the AOD. Still happening regardless even in safe mode it happens signaling this update is to blame.
- Ibuddy66
npmp
Galaxy
Galaxy S24
Im using S24Ultra.
This is a 7 day history, and always on display consumed about 67%.
Does anyone see the same problem? Can you see which app has high battery usage in Battery tracker app?
terminator9
Comet
Galaxy S24
i have same issue on s23 ultra, always on ..drains the **bleep** out of my battery especially overnight, i disabled it. you can also schedule it to turn on at a certain time and off at a certain.time.. you obviously dont need it on while your sleeping.
npmp
Galaxy
Galaxy S24
Yes, I've scheduled it. 5:30am - 12:30am
npmp
Galaxy
Galaxy S24
I had a chat with samsung customer service via text. They're suggesting to close unused apps. A waste of time 1709419660348.jpg
npmp
Galaxy
Galaxy S24
But 67% is too bad. If we've to disable, why does it even exist?
I don't remember seeing this in my S22 ultra. I suppose they messed up competing with iPhone's AOD.
