Galaxy S24 Battery Drain
(Topic created: 01-28-2024 05:28 PM)
GitDatPC
Galaxy S24
Always On Display drains nearly 2% of battery per hour on my S24 Ultra. This is much higher than the S23 Ultra. Hopefully this will be fixed in an update?
JUMP TO SOLUTION
Arthie
Galaxy S24
Whats your SoT now?
arturocarce
Galaxy S24
4:33h and still 37% left. Before (yesterday) with 4:30h of SOT light use I had 15% left. I have the phone since Jan 24.
Please, report if it has some effect on yours. Thanks!
usersZ51L4rEHa
Galaxy S24
Any updates if it's helped?
chinscd
Galaxy S24
I've been facing battery drain by system usage. It's usually around 40% with 60% being app usage.
Is anyone facing the same issue? What am I doing wrong? With these numbers I am getting 5hrs of SOT.
Tarrahs12
Galaxy S24
Same and samsung just gives me the run around about getting a newphone I have the 24+ and have turned off all background apps they told me to do a soft reset then a system cache reset.
Tarrahs12
Galaxy S24
bestyvabraham
Galaxy S24
Did that helped you
userBkeDFFQtck
Galaxy S24
I wouldn't mind I'm pre-order received it early had the same problem burning right through the battery and I did two cycles where it burn right through the battery and then charged it after it died and the battery is only getting worse. I just returned the phone
userYUGQeG9Nwq
Galaxy S24
I think I finally figured out the issue on my phone. The problems started when I turned on the battery protection mode. I turned it off today, restarted, and battery life is now great.
GeekRoger
Galaxy S24
Same here, I thought the phone battery was defective and the phone was returned and replaced. Replacement got the same issue. Mine 4 hours of SOT.
