Galaxy S24 Battery Drain
(Topic created: 01-28-2024 05:28 PM)
GitDatPC
Galaxy S24
Always On Display drains nearly 2% of battery per hour on my S24 Ultra. This is much higher than the S23 Ultra. Hopefully this will be fixed in an update?
JUMP TO SOLUTION
Khattak1122
Galaxy S24
I am thinking to return this piece of draining battery junk. And get back to iphone 15 pro max..
MatthewReiter
Red Giant
Galaxy S24
Let it adjust for about 7 days. It's learning your usage patterns
Khattak1122
Galaxy S24
To be honest. Its more than 7 days
Robin621k
Honored Contributor
Galaxy S24
You have to let it completely drain, at least 3 times.
I have had my phone since Monday, right now my battery page says I unplugged my phone 24hrs ago, I still have 20% battery.
I have watched 2 hrs of YouTube at Max everything!
I am a super power user, yesterday was 9hrs of Sot and it still has battery left.
Khattak1122
Galaxy S24
Let me try that
bestyvabraham
Galaxy S24
Is that OK to drain it till the phone turn off
LongHiker
Galactic Samsung Care Ambassador
Galaxy S24
@bestyvabraham "Is that OK to drain it till the phone turn off"
It is not recommended to drain a LiIon battery to 0%. It can result in battery damage.
bestyvabraham
Galaxy S24
It's more than 7 days and I am still having battery drain
Annmaryeloice
Galaxy S24
I noticed in the very 1 st day that s24 ultra battery is draining like anything. I have I phone 13 pro max also (more than 2 year old) . It has much greater battery left eventhough it has more use than s24 ultra. Now I am thinking I was wrong to purchase thing and I should buy 15 pro max
Khattak1122
Galaxy S24
Trust me return this piece of 💩. Go for 15 pro max. Its last 2 days
