- Mute
01-26-2020 11:24 AM in
HD and UHD TVsTrying to set up an external antenna to access regular broadcast stations to my Samsung TV (un55mu7000f) and I am not seeing the option to access it. According to the guide, I should be able to click the "Home" button on the remote and then I should see a "Live TV"option - but I do not see that. Choosing "Source" from settings doesn't give me any choices for antenna either. Any help would be appreciated.
Solved! Go to Solution.
- Mute
01-27-2020 05:49 PM in
HD and UHD TVsOn the remote press the menu>broadcasting>scan>air and it should find the channels for you once you do that you should be able to choose TV as the source
- Mute
01-26-2020 12:34 PM in
HD and UHD TVsWhen choosing sources do you see a source that says TV?
- Mute
01-26-2020 04:02 PM (Last edited 01-26-2020 04:03 PM ) in
HD and UHD TVsSamsungCaleb, I do see a source that says "TV" but the icon for it is "TV+" - but that is just the Samsung content.
- Mute
- Mute
01-28-2020 03:56 PM in
HD and UHD TVsI was having no luck so I disconnected the antenna and hooked it up on another TV and it worked. Thinking I may have orinally had it hooked up wrong on my Samsung wall-mounted Smart TV, I tried again with the location of the antenna in the sames spot (on the wall behind the TV) but still no luck. I decided to bite the bullet and run the unsightly wired antenna over to a window and voila! - it worked. Started scanning and identifying channels with no problem. So I am all set. Thanks SamsungCaleb!
- Mute
01-28-2020 04:00 PM in
HD and UHD TVsThat's good to hear! And you are very welcome!
- Mute
03-18-2020 01:03 PM in
HD and UHD TVsHow did you scan channels?
- Mute
12-06-2020 12:36 PM in
HD and UHD TVs
- Mute
12-07-2020 12:02 PM in
HD and UHD TVsI would be more than happy to take a look at this. Could you provide the model of your television?
- Mute
12-07-2020 12:11 PM in
HD and UHD TVs
