No sound out of subwoofer on HW-Q70T soundbar
(Topic created: 12-06-2020 03:20 PM)
usersjcVb5RPLk
Home Theater
Subwoofer connected wireless to soundbar.  Solid blue light, but no sound, vibration or anything.  Tried everything but no help.
JUMP TO SOLUTION
userMTzBkBBhM4
Home Theater
Same problem, blue light indicates a good connection. I have manually reset the connection several times.  Zero sound coming out of the subwoofer.
user1EzZT2D4jT
Home Theater
So are we going to get any help on this? I have a 55" Q80T purchased in November and I just bought the HW-Q70T. Hooked it up following the order from the directions and connected the sound bar via HDMI eARC. The sound bar works fine but the sub does absolutely nothing. It has a solid blue light indicating it is connected but still nothing. I have repeatedly done the ID SET button on the sub and each time it reconnects giving a solid blue light. But still nothing. So worthless.
userLi9szKjgug
Home Theater
Hi any solutions or fixes yet from Samsung.
I'm having the same issue. Q90T tv connected via eARC to Q70T Soundbar. All paired up OK.
No sound from sub.
Tried repairing. Firmware update. New eARC compatible HDMI lead. Tried other external devices.
Nothing, no sound at all.
Very disappointed as was expecting something special with the Q Symphony system.
Please help...
BarIL
Home Theater
Same issue with Sony Bravia TV (Connected via HDMI/ARC).
But the sub won't produce any sound even when streaming via bluetooth
Sub is linked with solid blue light.
Does Samsung team even read this?
Not applicable
Home Theater
There seem to be some different issues going on in this thread. Are you all having this issue with the HW-Q70T? Does it occur with all sources and inputs? Have you tried changing the sound mode or increasing the subwoofer level from the remote?
Have you all tried unplugging and re-pairing the subwoofer? Does the issue persist if you move the subwoofer closer or place it in a different corner of the room?
user118i8OFu0N
Home Theater
I have the same issue on a Q60R, the subwoofer light is solid, when i press the link button on the subwoofer it just dims the light. I tried the unplug and reconect everything but no luck, do you guys have come to a fix? Thanks (:
SamsungLK
Home Theater
Hey, give this link a shot: https://www.samsung.com/us/support/troubleshooting/TSG01110401/ If this does not help I recommend letting a service technician have a look. As we would like to gather additional information and look at this from a case by case basis please provide the full model code and the serial number of the device as well as your best contact phone number, name, and email.
Send a message on Facebook
Send Message on Twitter
Send Message to Moderator
