Is Water from Refrigerator Dispenser Chilled
(Topic created: 08-10-2022 05:01 PM)
userquFYWpZs9L
Kitchen and Family Hub
Is my refrigerator water supposed to be chilled?
Samsung_Moderator
Hi there, I'm so glad you asked! The refrigerator has an internal reservoir that holds about a quart of water, or approximately 2 - 4 glasses. If the water from the dispenser is not cold, then the cold water in the refrigerator's reservoir has been used up, and it will take time to cool again. Additionally, during the summer months, water enters the fridge at a higher temperature, which increases the time it takes to cool down.
1 Reply
Samsung_Moderator
